rear u-joint replacement
Old Jun 19, 2010 | 11:48 AM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Default rear u-joint replacement
I did a search for this and came up with very little to answer my question.
searched "rear u-joint replacement"
so here goes, I need to replace the u-joints on the 96 4x4 blazer (Rear shaft).
I do not see the snap rings that I am used to seeing.
I see the white pins ??
I see a post here that said heat them up.
Can I uses a propane to get it hot enough to get the caps out of the yoke ??
Old Jun 19, 2010 | 12:56 PM
Beckyj636's Avatar
Well I tried it and it did work , just took a bit a time. All is good
josemateos
Feb 18, 2014 10:00 AM
Guntheone
Dec 4, 2010 05:59 PM
97Bravada
Jan 14, 2010 05:51 PM
soundguy
Aug 23, 2007 08:03 PM
ejoy1220
Oct 8, 2006 06:45 PM
