rear window washer tube leaking on 2000 blazer?
Old Nov 3, 2011 | 08:46 AM
2000blazerdriver's Avatar
2000blazerdriver is on a distinguished road
Default rear window washer tube leaking on 2000 blazer?
I'm a newbie so bare with me if I am asking advice on something that has already been addressed. I have a leak in the rear window washer tubing that is draining the washer container. I have temporarily plugged the the line at the reservoir. I don't know how to get to the hose to fix it. Tips and advice is appreciated.
Thanks
Old Nov 3, 2011 | 08:58 AM
*Moved to 2nd Gen Tech* - Please read the descriptions of the forum sections on the home page and choose the section that seems most appropriate for the topic you intend to post about. Also, the search tool can be a great resource for finding what others have come across in the past.
Old Nov 3, 2011 | 09:01 AM
Thanks for pointing me in the right direction.
Old Nov 3, 2011 | 09:56 AM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
Had exact same problem, there is a tube under the carpet with a connection in the rear cargo area the disconnects. Easy to fix, just allot of time because have to remove allot of the plastic molding on the inside. Then reconnect the tube, and prop the carpet up with a board to dry to about a day. Just take your time with the molding so you don't crack any and should go fairly easy.
the tube is right about in the middle of the bottom of the sub.
Old Nov 3, 2011 | 10:49 AM
Right on. Thanks. Fixed it. Now to get that carpet pad dried out.
Old Nov 3, 2011 | 10:54 AM
gojorg's Avatar
I had the same problem when I bought mine and after fixing it under the carpet it came loose in the tailgate
Old Nov 3, 2011 | 03:10 PM
redcruiser's Avatar
redcruiser is an unknown quantity at this point
Mine came loose in the engine compartment somewhere near the firewall, never have had it fixed, not sure if the pipe goes into the car or under. Mine was a frozen pipe the first winter I had the Blazer
Old Nov 3, 2011 | 08:32 PM
Smitty Smithsonite's Avatar
yep - one of the many problems I had with my '00 Jimmy. That one had the tube disconnect from the rubber connector under the rear cargo floor. Then I worked on someone's "01 Blazer which had the same line disconnected in the hatch. What a crap design this is.
After you get it back together, crank on small zip ties on all the rubber junctions so it doesn't happen again ... because I can guarantee you it will.
strange
Dec 24, 2014 05:31 PM
skarphace
Sep 9, 2012 07:31 PM
builder125
Apr 4, 2011 05:27 AM
riceh8r0512
Dec 31, 2007 07:37 PM
