Recommendations on an OBD 1.5 Scanner
Old Apr 26, 2012 | 09:41 PM
klote82's Avatar
klote82 is an unknown quantity at this point
Default Recommendations on an OBD 1.5 Scanner
After doing some google searching ive found a few GM sites, and some of their users say that a particular scanner works better than others. Obviously since im new to this I have no idea if this is true.
So basically here is my question. Since I have a 95 with a OBD 1.5 setup Ill need that type of code scanner. Does one brand work better for our vehicles versus another? If not what brand would you guys suggest?
(I tried to search the forums on this and didnt find anything.)
Shawn
Old Apr 26, 2012 | 10:55 PM
billfrank85's Avatar
billfrank85 is on a distinguished road
Some of the better Actron scanners (OBD 2 compliant) will read 1.5 if you have the proper cable. They are one of the most widely used ones for home use.
Old Apr 26, 2012 | 11:04 PM
klote82's Avatar
Thanks for the reply. ok here is a pic of my connector and after reading so many complaints im assuming a obd 2 wont read the codes. so should i just go with a obd 1?
Old Apr 26, 2012 | 11:27 PM
An OBD 1 scanner isn't really much of a scanner. Basically, you're just shorting out certain pins in order to flash your check engine light. OBD 1.5 is a huge grey area since it was the transition to OBD 2. You have to have access to an OBD 2 scanner with the proper 1.5 cable to pull codes.
Old Apr 27, 2012 | 01:46 AM
RetroBlazer's Avatar
RetroBlazer will become famous soon enough
This and a laptop. I have one and I like it. It can't be used on OBD2 though so it's a bit expensive to buy for use on a limited amount of vehicles but if you own one, then it can come in real handy.
Old Apr 27, 2012 | 06:54 AM
volfan4's Avatar
volfan4 is an unknown quantity at this point
I have a '95 Blazer that states its an OBD2 on the emissions label and I own a OTC Genisys scanner that I bought used. It works on all domestic pre OBD2. Maybe it's the Scanner, but I use the OBD2 cable that's used on 96' and up. The unit I have only has the software built in to cover cars up to '03.
Old Apr 27, 2012 | 12:29 PM
klote82's Avatar
Retro thanks for that link. awesome! I think thats what ill do.
Appreciate all the replies yall..
Old Apr 27, 2012 | 09:50 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
All you need is a paper clip to pull codes from an OBD1.5 ecm. It's just an OBD1 ecm with an OBD2 connector. Figure out the pinout of the connector and you use the paper clip just like and OBD1 truck.
https://blazerforum.com/forum/2nd-ge...5-codes-49438/
Old Apr 27, 2012 | 11:30 PM
dano440's Avatar
dano440 is on a distinguished road
are these any good??
OBDLink SX
ScanTool.net LLC - OBDLink SX Scan Tool/OBD Interface - ScanTool.net
they seem cheap enough
Old Apr 29, 2012 | 04:03 PM
burned's Avatar
burned is on a distinguished road
OBDLink SX
I cant comment on that particular model. I have a Elmscan 5 USB from that site and love it. I use it with Scanmaster and PalmerPerformance software.
Its not comparable to a Snap On Verus, but its much cheaper.
