Refilling Coolant Issue?
Old Jul 8, 2010 | 03:43 PM
Red 96''s Avatar
Default Refilling Coolant Issue?
Alright, I just replaced the freeze plug in my engine block. In order to do that I had to completely drain the coolant. I drained a total of three gallons plus the little that I couldn't quite catch. Well now when I filled it back up, it only took two gallons. Does anyone know why this is happening? Thanks!
Old Jul 8, 2010 | 04:29 PM
adam10's Avatar
adam10 is on a distinguished road
did you run it till it got operating temp. to get all of the air out of it?
Old Jul 8, 2010 | 05:44 PM
Red 96''s Avatar
Yeah, I even drove it to work. The temp never went over the normal operating temperature. I checked the level before I left work and it didn't need seem to need any.
Old Jul 8, 2010 | 09:42 PM
Flatearthman's Avatar
Flatearthman is on a distinguished road
Try turning your heat on full blast after 5 minutes on idle or a quick trip down to the store.
i think you will need some coolant then around a half a gallon.
Old Jul 8, 2010 | 09:52 PM
Red 96''s Avatar
Haha, I tried that earlier. Its about a 20 minute drive home from work, so I drove with the windows down and heat blasting. I checked the levels after it cooled down and still no change. My neighbor suggested letting it run in the driveway without the radiator cap. He said, as it gets to operating temp, the radiator will become almost empty, so thats when I should pour the rest of the coolant back in. The problem is, I had to drain the block of coolant and I think there may be air in the system. Sorry for the long post but I really have no idea what to do
Old Jul 8, 2010 | 10:22 PM
well keep your eye on the temp and check your coolant tank daily.
fully drained and having the engine dissasembled capacity for an automatic is 11.7 quarts.
im sure you had at least 3/4 a gallon still in the system.
you can find fluid capacities in your owners manual.
section 6-66
Old Jul 8, 2010 | 10:40 PM
Red 96''s Avatar
Alright, thanks!
Old Jul 10, 2010 | 01:07 PM
Red 96''s Avatar
Before I try running it without the radiator cap, would I be able to fill the overflow tank, and then as the air bubbles are pushed out, the resevoir will empty back into the system? Seems like that would be a safer bet then running it without the radiator cap.
AcerDeucerQ
Dec 3, 2012 06:29 AM
Vtec2Slo
Apr 17, 2011 04:09 PM
monette9999
Apr 26, 2010 10:36 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
jdpilot
Jan 1, 2010 11:47 AM
