related engine codes?
Old Nov 30, 2011 | 08:06 PM
pd95blazer's Avatar
pd95blazer is on a distinguished road
I'm also thinking it could be the spider injector but not sure I've heard its a common problem with these trucks
Old Nov 30, 2011 | 08:21 PM
The injector assembly does have its issues, but it usually will set a cylinder specific DTC. With P0300, I'd bet on secondary ignition.
Old Dec 1, 2011 | 07:23 AM
pd95blazer's Avatar
Originally Posted by Captain Hook
P0300 is almost always set due to a fault with secondary ignition components: Ignition coil, distributor cap & rotor, worn distributor bushings and or gear, spark plug wires and spark plugs. I think you're on the right track... make sure you use AC Delco plugs.
I'm leaning more towards plugs and/or wires cause it ran perfectly fine before I did the work and it sat a for almost two months due to some out of town work.. would that make sense?
Old Dec 1, 2011 | 05:02 PM
Makes sense to me.
Old Dec 2, 2011 | 03:09 AM
pd95blazer's Avatar
Replaced the spark plugs and now she's back to running perfect thanks for the help hook
zlathim
Feb 13, 2018 04:22 PM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
