Relay Identification
Old Mar 30, 2008 | 03:52 PM
skoot61's Avatar
skoot61 is an unknown quantity at this point
Default Relay Identification
1997 Blazer LT 6cyl. 4x4 - My main intrest is where the turn signal relay is located. However, inside the glove compartment is a plastic cover that says: " Relay Access"under the cover there are 3 small electronic modules plugged into a 6 block terminal. (the other 3 opnenings are empty) They have all the same ID numbers which read : omron 12077866 D00 Does anyone know what these relay's control? Any suggestions or info is greatly appreciated. Thanks!
Old Mar 30, 2008 | 08:25 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: Relay Identification
Well in a bravada its all the way to the left but its also larger since I have towing package.
Old Mar 31, 2008 | 08:29 PM
skoot61's Avatar
Ok folks,heres the info .. Relays for the turn signal and hazard flashers are approx 1" round located under the dash boardbehind the cigarette lighter. Left relay controls the Hazard Flasher\Right relay controls the turn signal flashers. $4.95 each
Old Apr 1, 2008 | 08:49 AM
portcqb's Avatar
Must be prior to them adding the one large one in the glove box.
Old Apr 3, 2008 | 10:35 AM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
ORIGINAL: skoot61
Yes, that's for the '95-97s. I've replaced the turn signal relay before in my '96. However, please note that most relay locations changed, starting with the '98 models.
bestes
May 31, 2008 03:16 PM
ericjon262
Mar 17, 2008 06:27 AM
redneck_mechanic_187
Feb 12, 2007 11:45 PM
89Blazze
Engine & Internal
Nov 10, 2005 07:30 PM
88blazer
Engine & Internal
Feb 21, 2005 03:49 AM
