replace bearing right rear 95 blazer 4.3 4X4
Old Aug 3, 2012 | 05:39 PM
JCShelby's Avatar
JCShelby is on a distinguished road
Default replace bearing right rear 95 blazer 4.3 4X4
How do you get the axle loose?
Old Aug 3, 2012 | 08:59 PM
98blazin's Avatar
98blazin is on a distinguished road
you remove the axle and pull the bearing with a 3 jaw puller.
Old Aug 3, 2012 | 09:14 PM
Remove the differential cover, rotate the carrier by
hand until you can access the retaining bolt:
Remove the retaining bolt, (5/16" or 8mm socket) from the pin,
Remove the pin, (slides out) push the axles inboard,
remove the C clips, (they'll probably fall out) pull the axles out.
brianp
Jun 1, 2020 10:30 AM
metalhead
Nov 28, 2008 02:46 PM
franks
Feb 10, 2008 06:40 PM
redpeppers
Apr 7, 2007 04:55 AM
keeskc
Jun 6, 2006 03:07 AM
