Replaced ball joints. What a difference!
Old Jan 21, 2009 | 08:18 PM
The Beep's Avatar
The Beep is an unknown quantity at this point
Default Replaced ball joints. What a difference!
Replacing the ball joints really tighened up the steering and made the truck easier to control. I thought ball joints were for suspension only but they helped the steering alot. Expensive repair though. The old ones had to be air chiseled offto the tune of $950.
I just need the outer tie rod ends replaced. The rag joint appears to be good. There is light at the end of the tunnel.
Old Jan 21, 2009 | 09:48 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: Replaced ball joints. What a difference!
$950???[sm=yikesomg.gif]You got ripped off napa premiums are like $65 and labor max 3 hours if that. Should have been able to get that done for $500 parts included. Only 2 have to be chiseled out the other 2 bolt in. I did mine in my garage with a compressor that barely ran the chisel and it didn't take me 3 hours.
Old Jan 22, 2009 | 06:12 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
I disagree...If OEM they ALL are riveted in. Done 500 of these. If bolted(either upper or lower) someone has been there and done that! As far as the price....if you're happy-Beep, then...hope they used top shelf ball joints. Anyway...Jerry
Old Jan 22, 2009 | 08:02 PM
The Beep's Avatar
It was CarX. I know they hose you down with huge mark-up's on their parts. I think he said they were using AC Delco and they were about $125 ea. Midas was quoting similar prices.
However, I found a mechanic that works on the side. Future repairs should cost about half of what these past repairs have been. I wish I could have found him eariler.
abig84
May 27, 2013 10:41 PM
reelbroke2
Feb 29, 2012 08:32 PM
LoLoS10Blazer87
Suspension Tech
Sep 19, 2008 07:43 PM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
hdlogistics
Suspension Tech
Dec 2, 2005 10:53 AM
