Replaced EGR valve Still idle heavy
Old Sep 14, 2007 | 04:30 PM
splifton's Avatar
splifton is an unknown quantity at this point
Default Replaced EGR valve Still idle heavy
I performed a diagnostic on my 1995 Chevy S-10 blazer 4.3L Vortec and it said:
P0401 EGR Flow Insufficient.
I replaced the EGR valve and it is still idling heavy(RPM gage bouncing).
Any suggestion as to what I try next?
Old Sep 9, 2008 | 11:49 AM
Z28Justin's Avatar
Z28Justin is an unknown quantity at this point
Default RE: Replaced EGR valve Still idle heavy
i have the same problem i cleaned the egr valve and passage and it still will not go away. anybody know what else could be wrong?
Old Sep 9, 2008 | 11:58 AM
Wow... Old thread.
Want to fill us in on what it is you are driving Z28Justin?? Do you get this same code? Have you cleaned far back on both sides of the EGR passage? It could be restricted by carbon further in the intake or head.
Old Sep 9, 2008 | 02:05 PM
Z28Justin's Avatar
yea sorry i didnt wanna start a new thred when there was already one. i have a 95 blazer 4x4 4.3 vortec, i pulled the egr off and soaked it and used fi cleaner and compressed air to clean as far as i could in the mani, put it back together with a new gasket (with the carbon screen) and 3 days later the p0401 code came back up. so far i have done cap rotor plugs wires 02sensors and new cat. but cant seem to get it to idle smooth.
Old Sep 9, 2008 | 02:26 PM
The P0401 may not be causing the poor idle. Insufficient flow would be more in the form of a problem with the EGR supply pipes. You may need to use a long pipe cleaner to clean these tubes out. If there is a large restriction in one of these pipes (typically the supply pipe from the exhaust), then it can trigger this code.
Old Sep 9, 2008 | 05:07 PM
Z28Justin's Avatar
i think im gonna buy a new egr valve, i have something that might work that i use to clean my paint guns to clean the manifoild. i hope that fixs it, is carbon build up really such a problem in these motors?
Old Sep 9, 2008 | 07:31 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
My 95 went through about a two year period, where I had to have the EGR cleaned, about every six months. It eventually stopped(for no reason), and I drove it 3-4 more years, without it ever happening again.
Old Sep 14, 2008 | 03:53 AM
Way Cool Jr.'s Avatar
Way Cool Jr. is an unknown quantity at this point
my 95 is doing the same thing but it also dose it when im driveing and i had the egr replaced with the screen filter and the intire motor vacum cleand at a local shop im confused as i can be about it lmao
Old Sep 14, 2008 | 10:57 AM
Z28Justin's Avatar
i put in a new tps and it smoothed it out alittle bit but didnt fix it.
optimus485
May 12, 2012 07:07 PM
Rider
Feb 27, 2012 03:28 AM
Sandman_3
Sep 18, 2011 01:21 PM
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
95Jimmy
Oct 4, 2009 07:21 PM
