Replaced the fuel pump on my 99 Blazer....
Old Mar 18, 2012 | 06:04 AM
Blazed&Confused's Avatar
Blazed&Confused is on a distinguished road
Thumbs up Replaced the fuel pump on my 99 Blazer....
Just got done replacing the pump only on my 99 Blazer. It is possible to replace just the pump and save yourself a lot of money. My fuel pump decided to go out a few weeks ago, and after taking out the pump/sending unit assembly, I figured I would try and disassemble the unit and see if the pump was easy to get out and if I broke it, I would have to replace it anyway. Everything just snaps together so it was easy to disassemble and get the pump out. The pump is just your standard in-tank fuel pump. Thanks to some research online I was able to find a pump that had the same volume and PSI as the factory pump. Went to Autozone last night, picked up a new pump and strainer for about $90 out the door. Went home put everything back together, primed the system, and she fired right up. I will have to post up the info on the pump and strainer later so if anyone wants to attempt this, they can. Nothing like saving about $225 bucks.
Old Mar 18, 2012 | 08:48 AM
pettyfog's Avatar
Cool
Originally Posted by Blazed&Confused
Just got done replacing the pump only on my 99 Blazer. It is possible to replace just the pump and save yourself a lot of money. .... Thanks to some research online I was able to find a pump that had the same volume and PSI as the factory pump. Went to Autozone last night, picked up a new pump and strainer for about $90 out the door. ... Nothing like saving about $220 bucks.
I think I'm gonna sit this one out....
Old Mar 18, 2012 | 09:05 AM
coolasice's Avatar
coolasice will become famous soon enough
what brand was the pump?
Old Mar 18, 2012 | 09:32 AM
I know everyone is probably gonna bust my ***** for this one, but I bought the Airtex one. NAPA sells their line as well for a bit more. Let's just hope I'm lucky with the Airtex one.
Old Mar 18, 2012 | 04:00 PM
smartieab's Avatar
smartieab is on a distinguished road
Default Not to Rain on your Parade
In the last 5 years I have replaced the pump twice. First was and Airtex. It died 18-24 months later, so I tried another aftermarket brand. The sender died within 8 months on the second replacement. For the last year or two I have been having my wife fill-up every Friday, (its her low milage car). She is squaking about it so I am about to bite the bullet & replace it with an AC Delco from www.Rockauto.com for about $270.
I hope you have a better experience then I did.
Old Mar 18, 2012 | 05:19 PM
Well hopefully I will have good luck. Luckily the guy that had the Blazer before me made an access hole above the tank so I didn't have to drop the tank. It's actually pretty easy to replace just the pump. I believe the Delco # is a EP381.
Old Mar 18, 2012 | 05:27 PM
pettyfog's Avatar
Why not Delphi... it's 20 bucks cheaper.. and more than likely the same damn part.
Maybe if Delphi starts getting aftermarket sales they'll give their office and internal sales retirees some of their pensions they depended on.
How would YOU like it if you were GM salaried for over 20 years and the ****ing unions cut you off at the knees!
http://www.delphisalariedretirees.org/delphi/
Old Apr 30, 2012 | 05:05 PM
GaryRoe's Avatar
GaryRoe is on a distinguished road
Default Where?
Where do you cut the access? Any pics?
BouncingRadical
14
Nov 27, 2015 12:30 AM
aerovette99
46
Sep 28, 2015 10:04 AM
north40s
Oct 19, 2011 05:00 PM
mr30217
Oct 28, 2010 10:07 AM
LittleT
Oct 17, 2007 09:45 AM
