Replaced Heater Hose, now no ac
Old Jun 20, 2009 | 05:57 PM
LemonBlazer's Avatar
LemonBlazer is on a distinguished road
Default Replaced Heater Hose, now no ac
Hello all,
Yesterday, my heater hose split and I ran hot getting home. Not to red, just really warm. I let the engine cool down and replaced the hose and refilled coolant. Today, I went for a test drive to make sure everything was good to go.......now ac does not work [just blows hot air]. The compressor will cut on and off in cycles every 3-4 seconds. I just had the system refilled and checked for leaks 1 month ago and it was good to go, so I don't think I am low on refrigerant. I have tried putting a jumper on the connector to the AC clutch cycling switch [on the silver canister] to keep the compressor on - it will stay on, but still hot air. Possible I bumped an AC line that may have been ready to leak I guess, and pushed it over the edge :/ But is there anything it could be.
Thanks All
1995 S10-Blazer 4WD 4.3L Vortec
Old Jun 20, 2009 | 05:58 PM
Anything else it could be I mean?
Old Jun 21, 2009 | 04:17 PM
FLEMTP's Avatar
FLEMTP is on a distinguished road
When you jumper the compressor does it squeal or make noise?
Go buy a cheap low pressure port gauge and check the pressure in the low pressure port on your A/C also.. see if there is a lack of pressure.
Old Jun 21, 2009 | 07:40 PM
Compressor makes no noise, but there is virtually no pressure in the system when the compressor is running via jumper - I purchased a uv leak test kit and found dye on the back of the compressor (couldn't pinpoint source - may have even been from someone else previous test) and some actually found come on my fan! yet none on front of compressor?? Is this sign of me needing a new compressor you think?
Old Jun 21, 2009 | 09:26 PM
Sounds like a blown rear compressor seal. I would say a new compressor is at least the start of the repair. Make sure to look everywhere along the system to see if you can find more dye.
Old Jun 22, 2009 | 02:53 PM
Thanks for the advice. Anyone know of a good company that sells cheap compressor w/ clutch besides the standard Autozone, Advance, etc.
slcblazer
Apr 19, 2013 12:31 PM
RANDO
Mar 13, 2013 09:54 PM
86TransAm
14
Dec 13, 2011 07:46 PM
mcatnova
May 17, 2010 06:27 AM
rob1621
Apr 3, 2008 08:55 PM
