Replaced heater core now water pump is squealing
Old Jan 31, 2013 | 01:33 AM
RANDO's Avatar
RANDO is on a distinguished road
Default Replaced heater core now water pump is squealing
Chevy Blazer 2001..No Heating. Replaced thermostat and plugged heater core with new now Cabin heater works fine but water pump started squealing badly within 3 minutes of run time.. Replaced water pump with new but water pump started squealing again within 5 minutes. Replaced Radiator with new to increase flow to water pump but it still squeals loudly.. Could this be a ruined water pump or something else causing this in the cooling system? Seems like low circulation flow through Radiator.
Old Jan 31, 2013 | 10:32 AM
grizzstang's Avatar
grizzstang is on a distinguished road
Do you know for certain it is the waterpump squealing? I would pull the belt and spin all the accessory pulleys by hand to make sure you are looking in the right area.
Old Mar 13, 2013 | 09:54 PM
sinbig's Avatar
sinbig is on a distinguished road
I bet this was a belt
If you get any coolant on the belt it will glaze over and squeal like a stuck pig
slcblazer
Apr 19, 2013 12:31 PM
Steinbruchsoldat
Mar 23, 2011 04:37 PM
SSTBDriver
Jan 13, 2011 06:18 AM
mcatnova
May 17, 2010 06:27 AM
LemonBlazer
Jun 22, 2009 02:53 PM
