Replaced Intake Gaskets - Now no start...
Old Sep 6, 2010 | 01:26 AM
chilango's Avatar
chilango is on a distinguished road
Red face Replaced Intake Gaskets - Now no start...
I changed the gasket but i didn't mark the distributor. it's a 2000 s-10 blazer 4.3 with a EDI distributor. i have read and read the directions on the timing i saw at one of this post but i just can't align the rotor with de (6) mark. it is off a couple of degrees. i have tried to start it like that but it wont turn on at all. it will crank but no run. it does have fuel pressure i checked all the spark plug and cleaned them i doubled checked the timing but still can't get the pointer of the rotor to align to the (6) i have moved the shaft with a long screw driver to align it but still it won't align perfectly like it says on the instructions of the post. does any body have any ideas. that can help i would appreciate it thanks for reading this post.
Old Sep 6, 2010 | 06:32 AM
You should be able to get it to point straight at the 6. Sounds like you haven't properly aligned the two marks on the balancer.
*Moved to a new thread in the 2nd Gen Tech section* - The previous thread you posted in was on a different engine.
Old Sep 7, 2010 | 07:49 AM
latinoNJ's Avatar
latinoNJ is on a distinguished road
I had the same problem when I did my intake gasket.
What happened to me was that it will not fall on the 6 mark, if I pushed it down, it would rotate and miss the mark.
So what I did was put on the 6 mark, it wouldn't drop all the way down, but I manually turned the motor, the distributor would rotate and drop all the way down.
b-man85
14
Jan 19, 2015 02:13 PM
Dub_Villan
Apr 28, 2013 05:31 PM
spiderbalze
Oct 25, 2011 09:40 AM
drew_fur
Jun 8, 2011 03:52 AM
jasonscottclack
May 28, 2011 09:47 AM
