Replacement blnd door actuator for 1995 S10
Old Aug 12, 2011 | 11:45 AM
terryknapp's Avatar
terryknapp is on a distinguished road
Default Replacement blnd door actuator for 1995 S10
Do ou have to remove the entire dash to change this part?
Old Aug 12, 2011 | 11:47 AM
*Moving to 2nd Gen Tech* - Please read the description of the forum sections and choose the appropriate section for the topic you are inquiring about. The Forum Help & Suggestions Center is for forum software related questions & suggestions. Thanks!
If you cannot get to the blend door actuator through the glove box opening, then you have to pull the dash. It is located on top of the heater case inside the passenger compartment.
Old Aug 15, 2011 | 11:53 AM
terryknapp's Avatar
Thank you, I will look to see if I can remove the back part of the glove box. Looks like is molded or glued together.
Tony H
Sep 11, 2017 08:56 PM
shredyou
Sep 5, 2011 01:10 AM
Chevy33
Jan 9, 2011 07:26 PM
markrd
May 8, 2009 01:39 PM
