replacing fuel injectors
Old Apr 1, 2009 | 05:36 PM
blazer#3's Avatar
blazer#3 is an unknown quantity at this point
Default replacing fuel injectors
I have a 1999 blazer with a 4.3 I bought the upgraded GM injectors and the felpro intake gasket set, i also bought from GM the seal injector kit part # 17113205 do any of the black o- rings get used or were they put in the kit for use if you were going to rebuild your injectors???
Old Apr 1, 2009 | 06:29 PM
The kit is universal for both v8 and v6 use. There are o-rings for the fuel inlets as well as each individual connection into the main injector body.
I do not believe that you need this kit when you have the MFI spider. If I remember correctly from when I had done the MFI swap and LIM (both at the same time), the MFI kit came with all appropriate o-rings.
Old Apr 1, 2009 | 09:04 PM
blazer#3's Avatar
Question injectors
So I need to put an o-ring into each fuel injector inlet on the intake then push the new style injector into the inlet?? looks like there is no o-ring used in the intake inlet with the old style injectors?
Old Apr 1, 2009 | 09:09 PM
NO. The larger o-rings that come in the kit are definitely not needed in your case. They would only be used if you removed the individual injectors from the main injector pack body (remove the plate from the bottom, then pull out each injector. I do not believe you need to even have that kit as I am fairly sure that the MFI spider comes with new o-rings/spacers.
old88blazer
Sep 22, 2011 10:56 AM
Opi
Aug 13, 2011 12:06 AM
86Blazer4x4
Feb 8, 2010 03:46 PM
blazer#3
Mar 27, 2009 07:53 PM
mytruck2
Oct 10, 2005 12:45 AM
