Replacing Intake Manifold Gaskets
Old Aug 20, 2014 | 09:01 AM
koreiryuu's Avatar
koreiryuu is on a distinguished road
Default Replacing Intake Manifold Gaskets
Vehicle in question:
2001 Chevrolet Blazer, 2WD
I searched the forums and found this article:
https://blazerforum.com/forum/tech-a...-4-3-v6-46168/
THE ARTICLE ABOVE is for a '97 Blazer, which is in the same series and with the same V6 Vortec engine, so I'm assuming they're close enough to the same and I could just follow the above guide, but I want to be sure.
Does anyone know if there's a notable difference between these two years?
I noticed coolant leaking from the front of my vehicle, checked my radiator and hoses for cracks/leaks and nothing, and did some Google searching, there were a few Youtube videos that describe a similar problem and then show where coolant is pulsating out of the intake manifold. So here I am.
If there is a notable difference between the two years, I'd appreciate it if I could be advised of the important differences, or else if someone could link me to a more helpful guide. I'd hate to go out and buy the tools that guide lists as needed that I don't have to find out the guide is useless to me.
Old Aug 20, 2014 | 10:05 AM
burned's Avatar
burned is on a distinguished road
Old Aug 21, 2014 | 04:42 PM
koreiryuu's Avatar
Thank you burned
Old Aug 23, 2014 | 10:07 AM
koreiryuu's Avatar
While I'm at this, what other gaskets/seals could also be replaced? Any parts that should be checked or replaced? It's an '01 blazer at 135k miles, the spark plugs have been replaced, I regularly change the fuel filter, air filter, and clean the throttle body (about once every 6-12 months).
Old Aug 24, 2014 | 10:24 PM
koreiryuu's Avatar
bump!
Old Aug 26, 2014 | 10:09 PM
criadoman's Avatar
criadoman is on a distinguished road
There are several gaskets between both the upper and lower intake manifold, and that might depend on how you remove the manifold, and also why.
Check out this article - it might help you answer your question better...
How To Replace Intake Manifold Gaskets On A GMC Jimmy 4.3 Liter V6 To Fix A Coolant Leak - GM Truck Engine Repairs
gsaum
Apr 9, 2013 11:37 AM
kc0alg
Jul 16, 2011 09:41 PM
greg94
Nov 17, 2010 09:15 AM
Patrick_Boyle
Jul 9, 2010 12:30 PM
frankjc
43
Jan 9, 2007 12:02 AM
