replacing neutral safety switch, need help
Old Feb 6, 2012 | 06:29 PM
acfiero's Avatar
acfiero is an unknown quantity at this point
Default replacing neutral safety switch, need help
97 olds bravada, in the process of replacing neutral safety switch. i pb blastered the nut on the shaft coming through the switch 2 days in advance of removing it, but still, with only a small amount of force, the shaft twisted and snapped off. next- i pulled the switch off the shaft and a metal ring with some broken plastic is stuck on the shaft. so my questions are- 1) is that metal ring stuck on the shaft something that should come off with the switch or is it some sort of retainer that needs removed? how do i remove it? 2) should i just replace that shaft? bc if its too difficult i can easily weld the lever back onto the shaft
chappie74
Oct 17, 2010 10:42 PM
kship3
Oct 16, 2010 03:24 PM
metcalfr
Nov 23, 2009 01:07 AM
95_4door
Apr 14, 2008 07:39 PM
blazerssuck
Dec 5, 2006 08:14 PM
