Replacing Oil Pan
Old Aug 25, 2018 | 06:28 PM
masonmd's Avatar
masonmd is on a distinguished road
Default Replacing Oil Pan
I have a 1996 Blazer that got in an accident and the oil pan was damaged and needs to be replaced. I've read articles and watched videos. There's a number of different approaches including lifting the engine and other desperate measures. I currently have disconnected the CV axles from the inner hubs on both sides. There is enough play on the right side that I have pushed the axle back from the hub and disengaged it. The left side is a bit tighter but I believe I can pull if free from the differential once I disconnect the differential brackets and start moving it a bit. I'm just checking with anyone here who has actually replaced their oil pan to see if they have any words of wisdom or caution. Thanks in advance.
Mark
Old Aug 25, 2018 | 08:31 PM
Nola 77's Avatar
Nola 77 is on a distinguished road
I had the same thing happen to my blazer knucklehead hit my parked truck in front of a restaurant and bent the frame trashed the oil pan i bought a jimmy same year and put the engine from the blazer into it because the jimmy engine was grenaded by leaking oil cooler lines nd the blazer engine needed the pan from the jimmy to be whole again did the swap on an engine stand after pulling both motors so i really can't give you any advice on changing it in the truck only that it looked easier to do it out of the truck
snobrd
Jun 24, 2011 10:28 PM
Briz600
Aug 23, 2009 08:05 PM
andrea
Jul 15, 2009 09:51 AM
bobditts
Jun 18, 2009 06:38 AM
moonshiner500
May 11, 2007 05:58 PM
