Replacing radiator in a 2002 Blazer
Old Jul 8, 2010 | 02:49 PM
Maniboss's Avatar
Maniboss is on a distinguished road
Default Replacing radiator in a 2002 Blazer
I found a small leak at the top of the radiator, far right side, on the plastic endtanks.
I'm pretty good with DIY work, but have limited experience with Blazer repair.
Questions-
- Is there any way to repair a small hairline leak on the plastic tanks without doing a full radiator replacement? This particular leak is top right front (facing the truck), about three inches down.
- If a full replacement is required, are there any funky/unusual tools needed?
Thanks much for any insight.
Mani
Old Jul 8, 2010 | 03:24 PM
adam10's Avatar
adam10 is on a distinguished road
when my plastic end cap leaked i took to a radiator shop and they replaced the end cap and tested and cleand it for 1/4 the cost of new.they are really simple to take out (about 1/2 hour or so.i didnt use any special tools needed.
Old Jul 8, 2010 | 03:57 PM
Maniboss's Avatar
Thanks adam.
Are you referring to the hard plastic tanks on each end? If I'm reading correctly, the tank detaches from the main body of the radiator?
Old Jul 8, 2010 | 04:23 PM
adam10's Avatar
yeah you take the entire radiater out.the end caps are crimped onto the metal.the shop removes the bad plstic end cap and replaces it with a new one. its alot cheaper than a new radiator.i have not had a problem since.the shop told me they are prone to crack there because that is where the hottest antifreeze is always hitting.
Old Jul 8, 2010 | 05:20 PM
wlorton's Avatar
Full repair... Easy as pie... Done it a few times
Be sure to have some patience...
When I replaced mine I had the entire grille assembly off...
Just be careful with the AC lines that run to the condensor in front of it... (it is the condensor? i know it is part of the ac system)
Old Aug 5, 2010 | 03:53 PM
BDS_237's Avatar
BDS_237 is on a distinguished road
I just replaced my radiator this past tuesday. It too had the cracks in the plastic, but I had no idea that they could be repaired or replaced individually.
With over 150k on it, however, I'm sure it was just best to replace the whole thing. Good to be able to drive in traffic with my a/c on again!
Namtaru
Aug 30, 2010 10:23 AM
bigdaddykane93
Jan 4, 2010 12:03 PM
oem95blazer
Jul 19, 2009 06:38 PM
tmoble
Jun 15, 2009 09:39 PM
Taymacjack
Engine & Internal
Aug 28, 2007 07:58 PM
