Replacing signal flasher unit on steering column
Old Jul 11, 2008 | 12:27 PM
kbreck's Avatar
kbreck is an unknown quantity at this point
Default Replacing signal flasher unit on steering column
Does the steering wheel and air bag have to come off ????
99 chev Blazer
Old Jul 11, 2008 | 12:35 PM
Default RE: Replacing signal flasher unit on steering column
No. Only the upper and lower trim covers on the column (and other covers under the dash, etc). This part is called the multifunction switch which will help when searching through other posts discussing this component.
*Moving to 2nd Gen Tech* - General Chat is not for tech questions.
Old Jul 11, 2008 | 07:43 PM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
FYI: On my '96, a mechanic tried to replace the multifunction switch without removing the steering wheel. He ended up breaking the plunger for the Hazard lights. If your hazard light plunger passes throught the top cover, remove the steering wheel (and air bag). It is not hard to do. My recommendation is to get everything out of the way that you can, whenever you do a job. Yes, it is a PITA, but the new install will be so much easier, and you will have the opportunity to lube up all those fittings so IF you ever need to go back in, they'll be a snap to remove. Good Luck.
Malbo
May 1, 2014 12:04 AM
sifd4x4
Oct 26, 2010 12:56 PM
cas
Mar 20, 2010 12:57 AM
chapman55
Sep 29, 2009 10:58 PM
syrblitz19
Jun 10, 2006 02:27 AM
