Replced tranny, speedo problem
Old Dec 4, 2009 | 10:34 AM
lobo's Avatar
lobo is on a distinguished road
Question Replced tranny, speedo problem
I have a 97 blazer that I replaced the tranny on. Now the speedometer works intermittently, the ABS light is on, the service engine light is on, and the transmission won't start in 1st unless I manually downshift???? HELP!!
Old Dec 4, 2009 | 10:42 AM
Your truck is screaming at you! Get the codes read. It's trying to tell you what is wrong! You may have to find someone with a full feature scan tool to access the ABS codes, but I bet your ABS codes and your speedo problem are related (VSS).
Old Dec 4, 2009 | 11:50 AM
lobo's Avatar
I kind of figured that. It's just strange because everything worked before I put in this transmission? Thanks!
Old Dec 4, 2009 | 12:44 PM
Inspect the VSS (vehicle speed sensor). Remove it and clean it up. Inspect the connector.
Old Dec 5, 2009 | 08:35 AM
lobo's Avatar
Thanks, I am not to familiar with this electric stuff. Which plug is it? I am guessing that it would be on the output of the transfer case?
Old Dec 5, 2009 | 12:39 PM
cc4usa's Avatar
cc4usa is on a distinguished road
do a search on the vss and it should come up with a few suggestions
S10BlazerFTW
Jun 16, 2013 03:35 PM
curtiesdad
Apr 16, 2012 11:24 PM
wildmaninid
Jul 20, 2010 12:10 AM
KYTrailblazer
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Nov 1, 2009 10:59 AM
woodsballr
Jul 7, 2007 11:03 PM
