reverse vibration/shutter from rear end
Old Feb 1, 2009 | 04:12 PM
2blzers's Avatar
2blzers is an unknown quantity at this point
Default reverse vibration/shutter from rear end
have 1995 chevy blazer 4.3 auto when you apply a little more gas from a stop like backing up our driveway there is a pretty harsh vibration/shutter just for a second or twothen goes away. can travel in reverse at different speeds without this happening just when there is a call for more tork/power in reverse. no other noises or symptoms normal 1-3 second delay to catch when you put in reverse vehicle has 165,000. any thoughts?? vehicle has not been beat on, pulled some one out of ditch in reverse this winter took abit though.
thanks ahead of time!!
Old Feb 1, 2009 | 05:06 PM
Mammys Car's Avatar
Mammys Car is an unknown quantity at this point
Default RE: reverse vibration/shutter from rear end
Check the u-joints.
Old Feb 1, 2009 | 05:49 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
I know you don't want to hear it but it could be signs of trans problems.
Old Feb 2, 2009 | 03:18 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
ORIGINAL: SockJock
X2.
My 4T60E(front wheel drive) made the same noise/vibration while in reverse attempting to back into my driveway. After tearing my trans apart, among other problems, found my reverse reaction drum chewed up. I have a pic somewhere around here.
Old Feb 2, 2009 | 03:00 PM
blzR's Avatar
blzR is an unknown quantity at this point
Get under your Blazer immediatly and check for U-jiont slop! I dam near lost my drive shaft down the highway last May,bugger was nearly in 2 pieces & just looking at it still freaks me out if it hit the highway wrong and bounced into the car behind me the wrong and potentially fatal situation, as nothing holds the front section on-just slides out if the rear comes out!
Old Feb 10, 2009 | 07:57 PM
2blzers's Avatar
took to shop said more than likely the reverse drive clutch starting to go.elected to go with remanufactuerd 2yr/24000 mile warranty. with 165000 on great running motor that should get me around for awhile. any service ideas on reman trannys earlier fluid change and or flush earlier than 30,000?
thanks
jmac219
Oct 6, 2021 09:49 AM
joejiz
65
Apr 15, 2014 07:58 PM
TNTX3
Jan 23, 2012 04:42 PM
wienerdog
Aug 21, 2009 02:35 PM
Sabe
Jun 22, 2009 09:07 AM
