ride height different
Old Nov 5, 2011 | 04:00 PM
614blazer's Avatar
614blazer is on a distinguished road
Exclamation ride height different
my blazers right side seems lower than the left side in the front. what can cause this ball joints tbar stablizer bar. where to start. nothing seems broke. but i did replace the wheel bearing on the right side and lower and upper ball joint on the left can this cause ride height difference.
Old Nov 5, 2011 | 07:36 PM
chris015's Avatar
Do you have 4 wheel drive?
Old Nov 5, 2011 | 09:50 PM
Individual suspension components, such as ball joints, shocks, control arm bushings, etc, do not affect ride height. What causes ride height to change is the normal sag, (weakening) of the torsion bars and/or rear springs. Front chassis ride height is the vertical distance between the lower-most inboard point of the steering knuckle, nearest the ball joint, to the centerline of the lower control arm pivot bolt. Ride height is checked and adjusted when the vehicle is on a level surface. Factory specifications are as follows:
1996 & newer:
4WD (except ZR2) = 4.6” to 5.0” desired spec is 4.8”
4WD ZR2 = 4.6” to 5.2” desired spec is 4.9”
Rotating the torsion bar adjusters clockwise increases ride height, counter clockwise decreases ride height.
truckeez
Dec 21, 2012 05:49 PM
01Jimmy
Suspension Tech
Feb 14, 2009 12:56 AM
portcqb
Jan 23, 2009 10:11 AM
GregC5
Jan 8, 2009 10:50 AM
drq_92
Nov 26, 2007 09:22 PM
