is this right??
Old Sep 7, 2009 | 09:26 PM
young murph's Avatar
young murph is on a distinguished road
Default is this right??
so i have a 2000 trailblazer and when i put the turn signals on when the lights are off the front corner light and parking light blink at the same time, but when my lights are on they alternate (corner light blinks on off beat).. and also the right blinks faster then the left.
Old Sep 7, 2009 | 09:58 PM
okvortec's Avatar
They should alternate when the lights are on. When the lights are off, they will both blink at the same time.
Old Sep 7, 2009 | 10:56 PM
ok thanks a lot. i wasnt sure
Old Sep 7, 2009 | 10:59 PM
okvortec's Avatar
Glad to help!
Old Sep 8, 2009 | 01:11 AM
4x4blazerguy's Avatar
If you have one side flashing faster than the other you might need a NEW flasher.
Old Sep 8, 2009 | 01:11 PM
ok thanks
Old Sep 8, 2009 | 11:53 PM
BusaJoe's Avatar
BusaJoe is on a distinguished road
My TrailBlazer does the same thing.
Old Sep 16, 2009 | 02:24 AM
old skool luvr's Avatar
young murph, if one side flashes faster than the other, it's usually 'cause a bulb is burned out. check with the lights on, as i've seen a burned out running light cause a problem with the signal part of the buld (could be shorting out inside the bulb).
a flasher knows no difference between the left side of your truck, and the right side. it only affects how fast (or slow, if it's acting up) the cycle will be.
Old Sep 16, 2009 | 04:43 PM
yeah all the bulbs are fine, thats the first thing i checked so maybe its a short but no blown fuses..
and also all my lights flicker (head lights, dash lights, interior lights) i think its a ground but idk. any ideas
Old Sep 16, 2009 | 07:24 PM
yeah, start cleaning/checking the grounds-starting @ the battery and working back from there. obviously check the wires for damage as you go along too.
