Is this rim bad ?
Old Aug 27, 2009 | 04:07 PM
2005 Blazer's Avatar
2005 Blazer is an unknown quantity at this point
Default Is this rim bad ?
One of my rims has a kinda "spider webbing" affect going on in the center of the wheel. I get alot of vibrations when doing 65+.
I found a pic of a wheel on Ebay that looks like mine. I dont know if this rim is bad and therefore causing the vibrations, or if somethign else is.
Does anyone else have a similiar "spider webbing" on any of there wheels? Do you have any issues with it?
Any thoughts on the wheel condition?
Old Aug 27, 2009 | 04:23 PM
bulwaagh's Avatar
bulwaagh is on a distinguished road
Unless I'm missing something, that rim in the thumbnail looks a little oxidized, but _seems_ to be OK. Are you sure you just don't need an alignment and/or tire balance?
Old Aug 27, 2009 | 04:43 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Yah from the image all I can tell is that the finish isnt perfect. Maybe with a close up we could see somthing better
Old Aug 27, 2009 | 05:20 PM
Sisk's Avatar
Have you had your tires balanced after you noticed the vibration?
I'm with the above posters...I don't see anything wrong with that rim...but it's hard to see.
Old Aug 27, 2009 | 05:35 PM
TripleBlackBlazer's Avatar
I have acid wash on my rims as well, not sure how it got there or how to get rid of it, etc.
Old Aug 27, 2009 | 10:40 PM
Yeah, I forgot to mention. I have gotten a Roadforce balance by the dealer, which didnt help any. ( I noticed the "spider-webbing" effect a little while after the balance...Im not saying they caused it, only that if I had noticed it before I would have asked the mechanics doing the balancing about it.)
It does look like its only surface deep, but wasnt sure how it go there. I was thinking maybe the rim was warped and caused the surface to get the "spider webbing" / acid wash look.
I didnt want to go out and buy new rims or tires if I didnt have too. But just trying to correct the vibrations.
Old Aug 28, 2009 | 12:24 PM
420BLAZER's Avatar
420BLAZER is an unknown quantity at this point
From your picture it does look like oxidtion and I have the same on my rims and can provide a pic if you like. they run fine
Old Aug 30, 2009 | 09:05 AM
number13man's Avatar
number13man is on a distinguished road
could it be the rear u-joint? i had the same vibration at about 60+. i replaced mine ($15 at autozone) and my vibration went away.
hope that helps.
Old Aug 30, 2009 | 09:38 AM
portcqb's Avatar
Was the tire they balanced on that rim the same one that was on it with the vibration before balancing. You may have a broken belt or cord in that tire
Old Aug 30, 2009 | 11:02 AM
Thanks for the suggestion, Ill have to check it out.
Yeah it was the same tire/rim. how would I be able to tell is there is a broken belt or cord?
Last edited by 2005 Blazer; Aug 30, 2009 at 11:06 AM. Reason: trying to get the "quotes" to show properly
