rotor is stuck!
Old Oct 3, 2007 | 08:50 PM
blazerxtreme1's Avatar
blazerxtreme1 is an unknown quantity at this point
Default rotor is stuck!
Hey! I'm changing out everything in my rear braking system, but i have had trouble withthe passenger side rotor not wanting to come off... at first I had the E-brake on, once i figured that out I thought it would come off but guess what? its still stuck! I've tried the big hammer approach but nothing... now off to Walmart for some wd 40... Please help!
Old Oct 3, 2007 | 08:54 PM
Default RE: rotor is stuck!
Its going to be the internal drum parking brake hanging up. Easiest way to deal with it is to attempt to turn it while pulling on it. One way that I have found that works in situations like this is to get it jammed on the internal shoe so that you can't turn it from that side. Then, with the rear of the vehicle totally off the ground and the opposite tire installed, turn the opposite tire. It helps to have someone else there to keep the rotor on the internal parking brake. Eventually you will chew out all of the built up rust ridge on the inside of the drum and it'll come off.
I don't know how much WD40 will help in this type of situation.
Old Oct 3, 2007 | 10:24 PM
Thanks, I give that a try tomorrow. I just soaked itwith PB Blaster so i'll see what happends with that
Old Oct 4, 2007 | 09:02 AM
blazinblack's Avatar
blazinblack is an unknown quantity at this point
you could try a penetrating oil but then you would want to make sure to get that all off or your going to have problems stoping when you get it all back together
[align=left] [/align]
Old Oct 4, 2007 | 09:11 AM
You will only affect the parking brake shoe which can be cleaned with brake parts cleaner after the rotor is off.
Old Oct 8, 2007 | 12:26 PM
Hanr3's Avatar
I wonder if he got it fixed?
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
urbex
Jan 10, 2010 10:47 PM
kornphlake
Aug 11, 2006 05:55 AM
