Rotten egg smell
Old Mar 2, 2020 | 02:27 AM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Exclamation Rotten egg smell
Hello everybody
I have problem with my 00 jimmy when it run I smell rotten egg from the tail pipe even if you are far away from it. So, I think maybe the O2 sensor is bad which cause wrong air ratio mixture and this will result this smell. When I check under car there no O2 sensor nothing at all.
It is possible that the car run without O2 sensor?
thank you
Old Mar 2, 2020 | 08:22 AM
rriddle3's Avatar
Smells like a burned out catalytic converter.
Old Mar 2, 2020 | 09:23 AM
GeorgeLG's Avatar
There are no ports for O2 sensors in the exhaust pipes or the ports that are there have no sensors in them? Do you have any codes? What are your fuel trims?
George
Old Mar 2, 2020 | 11:54 AM
Exclamation
Yes, GeorgeLG exactly no ports for O2 sensors in the exhaust pipes nothing just normal round pipe and no codes, no engine light .
I see the original gm Catalytic converter it's not same. It doesn't have out shell. It seem like mini exhaust muffler.
Old Mar 2, 2020 | 12:33 PM
GeorgeLG's Avatar
I have no experience with a vehicle that has its closed loop/emissions system removed so I’ll defer to someone with experience in this level of engine mods/builds.
George
Old Mar 2, 2020 | 11:14 PM
Here are the photos of the exhaust system
This what I mention before it seems that the Catalytic converter swapped by small exhaust muffler.
Old Mar 3, 2020 | 05:17 AM
So it would seem that it has no more catalytic converter at all?
I go with George - have a look at the fuel trims. Without properly working O2 sensors the injection may be all off.
Old Mar 3, 2020 | 07:08 AM
Yes, no more catalytic converter there it seem was replaced by small muffler.
Yes here it's.
Old Mar 3, 2020 | 12:24 PM
Mods's Avatar
All the data on the right hand side is washed out and unreadable.
Old Mar 3, 2020 | 02:16 PM
Billy1820's Avatar
It looks like someone hacked out the O2 sensors and cats. Not a big deal if a speed density tune was properly done, but I'll bet a six pack that's not the case Your truck will just stay in open loop forever and run off the VE tables in the ECU. Is your CEL disabled too?
