rough cold start idle and rough running
Old Jul 17, 2010 | 05:28 PM
blazerguy22's Avatar
Default rough cold start idle and rough running
i know im probably reposting this for the umpteenth time. but i have an issue with my 4.3L 2wd running rough at idle and at first accelleration after sitting for a few hours. im thinking egr valve. any ideas?
Old Jul 19, 2010 | 08:49 PM
Doug Sample's Avatar
Doug Sample is on a distinguished road
why do you think the EGR valve? It really could be a million things.
Old Jul 19, 2010 | 09:03 PM
cause it only happens when cold. and once its ranf ro a few seconds and the egr valve has had a chance to unstick itself it runs fine
Old Jul 19, 2010 | 09:23 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
any lights on-one in particular..the check engine? thx, jp
Old Jul 19, 2010 | 09:27 PM
no. and ive already scanned it for stored DTC's Im a auto tech for a living but i work on VW's so im kind of at a loss here. love blazers and love chevys but all my training is in vw wat different systems.
Old Jul 22, 2010 | 04:41 PM
and now to add to it. its running hot and idk why
Old Jul 22, 2010 | 06:16 PM
randy2009's Avatar
randy2009 is on a distinguished road
pull the egr valve out and clean real good with carb cleaner and then install new gasket with the screan in it to keep particles of carbon from jamming the egr valve open.
Old Jul 25, 2010 | 12:30 PM
randy2009's Avatar
running hot doesnt sound good,mine did the same thing and i found out the head was cracked.you could try to pressure test the cooling system that should tell you if the head is cracked.i would also run a compression check on the cylinders.
Old Jul 25, 2010 | 08:03 PM
that was all done last year when i replaced the intake manifold gasket that blew. tested good. it just started running a bit warm like 240 or so. ac is bad too but oh well. ill check into it tomorrow i hope we have a pressure tester at work that will fit my truck
Old Jul 26, 2010 | 07:16 PM
ok no water leak didnt pressure test it but it hasnt run hot in a few days and its been scorching hot round here. and the rough start is a clogged EGR valve cleaned it with carb cleaner problem was fixed for a day or so but the valve is still sticking. and the truck is running rich as heck. yunkyard here i come!!!!!.
