Rough engine with P0300 code
Running rough, even more when you put it in drive. Did full tune up. Pulled the plugs today, and #3 and #5 were burnt/black. Thinking either head gasket or spider, any thoughts?
I would do a compression test to see what the compression is all around the motor. I would also pull the plenum and look for evidence of washing from leaking fuel. A fuel pressure and leakdown test is also a very good idea. With all of those tests you should be able to find what the problem is and get pointed toward a fix.
Finally got my hands on a compression tester. i only got one side checked. hoping to do the other side tomorrow. Got about 60 lbs in #3 and #5 cyl, but had over 100 lbs in #1. Im thinking its head gaskets. hopefully the head aint cracked.
Klturi421
34
Mar 19, 2012 10:11 PM
R134A
Sep 22, 2010 07:41 PM
98blazr
44
Aug 21, 2009 01:17 AM
