Rough engine with P0300 code
Old Jul 15, 2013 | 08:19 PM
palmer96's Avatar
palmer96 is on a distinguished road
Post Rough engine with P0300 code
Running rough, even more when you put it in drive. Did full tune up. Pulled the plugs today, and #3 and #5 were burnt/black. Thinking either head gasket or spider, any thoughts?
Old Jul 16, 2013 | 02:12 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I would do a compression test to see what the compression is all around the motor. I would also pull the plenum and look for evidence of washing from leaking fuel. A fuel pressure and leakdown test is also a very good idea. With all of those tests you should be able to find what the problem is and get pointed toward a fix.
Old Jul 16, 2013 | 07:28 PM
palmer96's Avatar
Finally got my hands on a compression tester. i only got one side checked. hoping to do the other side tomorrow. Got about 60 lbs in #3 and #5 cyl, but had over 100 lbs in #1. Im thinking its head gaskets. hopefully the head aint cracked.
Old Jul 16, 2013 | 07:54 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
still do a fuel pressure and leakdown test.
Old Jul 16, 2013 | 08:40 PM
palmer96's Avatar
I already did a fuel pressure check and it holds strong at like 56-58 psi. I don't have a leak down tester. I will ask around to see if I can borrow one though.
jack hammer
Dec 4, 2013 04:36 PM
Klturi421
34
Mar 19, 2012 10:11 PM
R134A
Sep 22, 2010 07:41 PM
98blazr
44
Aug 21, 2009 01:17 AM
JRXtreme
Feb 9, 2009 03:06 PM
