Running hot need and dont know why (97 blazer)
Old Sep 6, 2012 | 06:22 AM
dobyken's Avatar
dobyken is on a distinguished road
Originally Posted by bromanjr
You should get the proper thermostat in there, without a thermostat you have the possibility of water going too fast through the radiator to cool it down or possibly not allowing proper restriction for coolant to flow as designed.
I've heard this before but I'm not sure about the science behind it. The radiator has little slits that the water has to pass through which reduces the flow rate. If the thermostat is fully open does it restrict the flow that much more than without a thermostat?
Old Sep 6, 2012 | 12:06 PM
Presti7's Avatar
Presti7 is an unknown quantity at this point
I bet your intake manifold gaskets are shot. Mixing dexcool with regular antifreeze not only creates all that rusty mud, it rots away the gaskets under the intake manifold.
You say it runs hot. Computer may have shut down fuel injectors and engine is only running because fuel injector spider unit is shot and there's just enough fuel leaking past the closed injectors to run without the computer...but it would be really really lean and run hot. Common for wire harness wires to rub through and short out to keep the computer from opening injectors. It'll run without the computer pulsing the injectors in this scenario.
The wiring harness for these was poorly made. Mechanics wouldn't know the computer isn't even pulsing the injectors to get it to run. They would just see it running and never even think of it. the shot fuel injectors could be leaking enough fuel for it to run and the ICM provided barely enough timing advance without the computer to chug around but running lean/hot.
Laying under the truck and looking up at the radiator, are your rubber radiator mounts all melted and dripped down/burnt? Ask me how I figured this out....
Whatta crappy fuel injection design/wiring harness/computer software GM made for these piles of.......
Old Sep 7, 2012 | 05:24 AM
dOgGiE_VoMiT's Avatar
dOgGiE_VoMiT is on a distinguished road
Yes Presti7 they are melted and burnt. I pulled the radiator and fleshed it out and noticed them melted the day before I posted this.
jagblazer01
Jan 17, 2012 11:36 AM
timmy08753
Jun 18, 2011 08:57 AM
Mandrwj
Apr 10, 2011 07:32 PM
215stud
Dec 11, 2009 04:01 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
