running weird and threw all these codes at once
Old Jun 6, 2012 | 10:14 PM
killallblue's Avatar
killallblue is on a distinguished road
Default running weird and threw all these codes at once
well i came back for a work trip being gone for a week i get in start my blazer and it felt sluggish then started cuting out check engine light came on and threw all these
p0122
p0405
p0452
p0404
i looked them all up but any reason why they all came on at once
Old Jun 7, 2012 | 09:39 AM
spittybays
Guest
Posts: n/a
Try tapping the part of the egr that is attached with two bolts to motor with socket extension and hammer/remove egr and clean. Replace gasket with screened up-grade. Use di-electric grease on five pin connector. Sticky egr. Chunck O' carbon got tossed.
Old Jun 7, 2012 | 12:34 PM
well just changed tp sensor egr cleaned Evey sensor on top of motor and its still acting like its starving changing fuel filter now
Old Jun 7, 2012 | 01:08 PM
50lb_cat's Avatar
All of those codes are electrical issues. I don't think the fuel filter will change anything. Double check all of the wiring, and the wires from the pcm.
Have you tried to unhook the battery for awhile to reset everything? It sounds like electrical gremlins to me.
Old Jun 7, 2012 | 03:51 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Low battery voltage can cause lots of random CEL codes.
Old Jun 7, 2012 | 04:55 PM
war00's Avatar
war00 is on a distinguished road
x2 on the battery try trickle charging it
Old Jun 7, 2012 | 07:04 PM
Starving? Have you checked fuel pressure and leakdown?
Old Jun 8, 2012 | 12:04 AM
defently not batts i have 7 of them in my truck and there 100 pounds each lol
it was the fuel filter guys i changed it and it didnt throw codes and runs good
Old Jun 8, 2012 | 12:54 AM
50lb_cat's Avatar
Glad you got it figured out!
Old Jun 8, 2012 | 03:58 PM
Very common that a new fuel filter clears up the problem, especially if the fuel pump is weak. A partially restricted fuel filter puts added stress on the pump, a new filter would allow a borderline pump to perform acceptably....for awhile Did you check pressure & leakdown?
