runs like s**t and st-st-stutters!
#21
I would say that you should try to flush the block, radiator & heater core with water first to see how that goes. If you want something more aggressive, go with an actual cooling system flush chemical rather than soda...
Then start looking for the leak cause there is one somewhere that has allowed air into the system.
#22
you think air contaminated the coolant, causing this "sludge"? 'cause i sure don't see any traces of coolant leaks anywhere-unless it's @ the back of the engine...........
personally, i think it was just the lady who owned the truck (since new) before me. i had my friend @ GM look into the service history on the truck, where she bought it. even though there were current records right up to the Fall before i bought it, once it was out of warrenty, she did the bare minimum-at best-for the health of the truck.
#23
Even something as simple as a bad radiator cap can allow air into the system. Once air is in the system, it can rust the metal. I can get into the reasons why, but do not want to pull this thread off topic.
#24
funny that you mentioned the rad cap. i just replaced it last week when i did the thermostat-noticed that it had little spring pressure to it.
what was the stuff you were refering to for the flush? i'll take a guess it's a GM product?
#25
There are several different brands. Prestone has their flush kit that makes it somewhat easy to do.
#26
have you checked the range on your tps
#27
#28
preston makes a 10 minute super flush and also a 3 to 6 hour super cleaner.....i only tryed to 10 minute one becuasei cant leave regulator straight water in my radiator for long with these cold temperatures here...
#29
thanks for the info bdk, i'll check it out.
#30
Rather than Coke, try using Vinager, It eats the rust and corrosion, without the sticky burnt on sugar mess.
rd-blazer
18
08-05-2011 12:46 PM
ddog800
14
02-16-2011 03:01 PM
zakm0n
01-10-2011 11:42 AM
rpdandridge
11-01-2010 05:21 PM
Turismo
09-27-2009 11:30 AM
