S-10 blowing ECM1 fuse once you turn the key
Old Jul 28, 2014 | 06:47 PM
hmartin's Avatar
hmartin is on a distinguished road
Default S-10 blowing ECM1 fuse once you turn the key
Have a 02 S10 that is blowing ECM1 fuse once you turn the key. Fuel pump has been replaced. Had a friend look at it replaced the fuse truck ran good for a few days then died driving down the road. Check and the ECM1 fuse was blown again. Have replaced had the truck started, wiggled wires around the engine (suggested by a mechanic) shook the battery (less than a year old) truck started running rough and died. CONFUSED and HELPLESS....
Old Jul 29, 2014 | 04:20 PM
The ECM1 fuse feeds the ignition control module, ignition coil, all 6 fuel injectors, and also one of several feeds for the PCM. Check the pink wire to each of those components, and the components, for a short to ground. The crankshaft position sensor is NOT affected by the ECM1 fuse. Best to leave the CKP sensor alone unless there is a DTC in memory for the sensor, and following the flow chart specifically instructs you to replace it. If the sensor, or the timing cover, is moved, removed, replaced or disturbed, the crankshaft position sensor relearn MUST be performed with a scan tool capable of initiating the relearn.
Old Jul 29, 2014 | 04:35 PM
newguy's Avatar
probably not it, but I had this problem and there was a loom of wires that went over the passenger's side exhaust manifold that had melted to it. I would change the fuse, drive it, hit a bump and it would short and blow the fuse
Brother Marc
Jul 5, 2013 09:39 PM
mcmastrman
Jul 26, 2012 06:10 AM
LagWagon
Mar 4, 2011 07:43 AM
darkwarlord
Oct 20, 2010 10:48 AM
mrhockey4real
19
Aug 17, 2010 07:37 PM
