-   -   Sagging Doors - Which Pins/Busiings? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/sagging-doors-pins-busiings-79582/)
phxjosh May 30, 2013 09:47 PM
I have sagging doors and want to change out the pins and bushings on each side. I found a few different part numbers at autozone for what looks like the same part, which is the right part? And does this come as a set or 1 part per door?
1. Dorman/Door Hinge Parts (703-265) | 1996 Chevrolet Blazer 2WD 6 Cylinders W 4.3L SFI | AutoZone.com
or
2. Dorman/Door Hinge Parts (38419) | 1996 Chevrolet Blazer 2WD 6 Cylinders W 4.3L SFI | AutoZone.com
Thanks.
richphotos May 30, 2013 09:59 PM
I think both of those are the same, just different brand, even though the weight is different (might be made out of something a big different) as for how many, you will need 2 of those per door, as each one comes with one pin, and 2 bushings.
LannyL81 May 30, 2013 10:03 PM
You will also need to get a GM door spring tool; best price I found was at Harbor Freight Tools.
cleburne red May 30, 2013 10:07 PM
A year and a half later, and I still haven't gotten the spring back in my driver side door!!
richphotos May 30, 2013 10:22 PM
I got mine from napa for 19 bucks, since the bushings need to be replaced on these so often, it was a good buy
Toby Hanson May 31, 2013 12:43 AM
Don't be in too big a hurry there, Red. The spring just gets in the way the next time you replace the pins and bushings. :)
armykyle1 May 31, 2013 01:01 AM
Thank you! I keep trying to remember this but this was a great reminder. I'm gonna check napa for that tool.
phxjosh May 31, 2013 10:01 AM
Do I need to replace the spring as well?
Do we have a part number for the GM door spring tool? I will pick one up this afternoon.
richphotos May 31, 2013 11:40 AM
You dont have to replace the spring, and if you go to napa, they will be able to look in their catalog to find it if you tell them you need a door spring compressing tool
phxjosh May 31, 2013 12:20 PM
Can you do the pins without the door spring tool? Or is that required?
So I am looking at $30 for the pins and $19 for the tool, that isn't too bad.
Actually I found the part for $7.99 at Harbor Freight, can you guys confirm if this is the right part?
http://www.harborfreight.com/gm-vehi...ool-95344.html
