Same p330 different question?
Old Sep 3, 2011 | 01:51 PM
pdl122000's Avatar
pdl122000 is an unknown quantity at this point
Default Same p0300 different question?
I have the same problem as a lot of other people here, but was doing something different.While the engine was running I opened the air filter box from the top of the throttle boddy and engine died, could point to somthing else? All ready did tune up, changed fuel pump and filter,THANKS.
Old Sep 4, 2011 | 12:50 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
Could you give us some more information?
What are you driving?
How many miles?
History of the vehicle?
History of the problem?
We need you to paint us a picture so we can help.
Good luck!
Old Sep 5, 2011 | 03:32 PM
pdl122000's Avatar
Default po300
Its a 99 4door, 4wd, with about 140,000. Isaid it dies when I take the cover off air filter box,but I meant off the throttle body.its skipping under load and hard to start. also I was pricing on injectors and on some sites it states that it changes injection to multi port,is that right. thanks.
Old Sep 5, 2011 | 04:28 PM
bromanjr's Avatar
bromanjr is on a distinguished road
The MAF sensor is in the intake tubing near the air filter box. If you disconnect the tubing anywhere between the throttle body and the MAF you will cause the sensor to misread air flow and it will stall. That tubing must stay connected with no leaks while engine is running.
coolcat0285
Nov 14, 2012 07:35 PM
mikepro
Aug 15, 2011 07:03 PM
AmberRose
Aug 30, 2010 08:58 PM
Xander2002
Tires and Wheels
Mar 25, 2009 01:40 PM
BlazerBrendan
Oct 12, 2008 09:12 PM
