seat belt help
Old Apr 1, 2014 | 09:55 PM
Robt77's Avatar
Robt77 is on a distinguished road
Default seat belt help
I have a 01 Jimmy, some idiot cut out the seat belts. I just picked up a set from a 01 full sized blazer. everything seams to fit, but they are keyed differently. I could drill a couple holes to make them fit. My concern is will they unlock once installed (they only pull out if installed) if I do make the mod and they don't unlock, will the mod make the proper belts not work either?
Old Apr 1, 2014 | 10:29 PM
Robt77's Avatar
Update--- I'm an idiot. the locking has nothing to do with being installed (I thought it was a magnetic sensor or something) it's all about the angle. that being said does anybody know any reason I shouldn't use these belts?
Old Apr 3, 2014 | 03:59 PM
Robt77's Avatar
Default Well they are in
The only big problem I had was the lower front passenger side bolt. a little heat and 2 broken bits and it came out.
Old Apr 4, 2014 | 07:26 AM
Tajohns34's Avatar
Why not use a set from the same vehicle? I can't imagine they would cost a lot from a salvage yard.
Old Apr 4, 2014 | 12:15 PM
Robt77's Avatar
Default it's on my to do list
I'll probably go get the rear ones when I have time, but I needed them right away, and I got the whole set for $40. The good news is the front belts are a perfect fit.
Old Jun 18, 2014 | 11:57 AM
Jasongr81's Avatar
Jasongr81 is on a distinguished road
Got a question myslef about seat belts. Someone cut mine and wondered if there was a difference between the front and rear ones. What about 2 door and 4 door? I found one out of a 2 door and they say it will not fit on a 4 door. Anyone?
Thanks
Old Jun 22, 2014 | 11:23 AM
Robt77's Avatar
the front is the same in both, but the rear is different, I would recommend finding the correct ones. I managed to put the 4 door rear in a 2 door with very minor mods. also some years had the seat belts recalled, so if you put the wrong ones in the dealer probably wouldn't be able to help you if they needed replaced.
ChevyHead
Mar 12, 2015 03:53 PM
Mike mooney
May 17, 2013 07:05 AM
lionel2
Sep 7, 2012 02:45 PM
leeroy74
Jan 21, 2011 12:36 PM
