Serious Blazer problems...
Old 06-23-2010, 07:50 AM
Brandi1069's Avatar
Brandi1069 is on a distinguished road
Angry Serious Blazer problems...
Ok..I have a 1998 blazer that decided one day to quit on me. Since then, we figured out that it was a fuel related issue. We have changed...fuel pressure regulator, fuel filter, cam sensor, fuel pump, and the main computer.
I am not sure if at this point, we are locked out via the security or what. I have tried the 30 minute procedure that is listed in the form. The light will come on (not blink), I wait for it to go out (10 or so minutes) then turn off the key and wait 5 seconds to try to start it...then repeat if needed.
At this point, the battery is very low from trying this repeatedly.
The truck will start for a quick second, then shut off.
Someone please offer me some advice as I am at my wits end!!
I just am not sure if I am locked out, or if something has been overlooked.
Thanks,
Brandi
Old 06-23-2010, 07:53 AM
Brandi1069's Avatar
Forgot to mention..... fuel pressure tests ok and there are no codes coming up
Old 06-23-2010, 10:40 AM
HARDTRAILZ's Avatar
HARDTRAILZ is on a distinguished road
Put a charge to it and repeat the security. When i swapped my computer i had close to the same issues and i hooked up jumpers and kept the battery charged by running the other vehicle and then did the security and it worked.
Old 06-23-2010, 12:03 PM
Brandi1069's Avatar
I did hook up jumpers to it and I still can't get it to start. I have tried the relearn back to back several times in a row. It will run for a second if I put ether in the throttle body. Then it just dies back out.
I also just replaced the throttle position sensor today, and I am still in the same boat
Old 06-23-2010, 12:31 PM
HARDTRAILZ's Avatar
Can you manually feed it fuel and keep it running?
Old 06-23-2010, 03:28 PM
Brandi1069's Avatar
yes, if you keep pouring fuel into the throttle body it will run. As soon as it is gone, it dies. I am down to the injectors, or possibly a security issue. It gave me absolutely no warning, I just turned it off, and it wouldn't start back up. Any input is greatly appreciated.
Old 06-23-2010, 03:32 PM
HARDTRAILZ's Avatar
Ok. I am not claiming to be great at this, but just trying to help.
Did you make certain the new compuer is for your vehicle. I know I can only use an 05-06 comp I think and the 02 cant be used in any other year. That is for Trailblazers, but may be similar issue for you....
Old 06-23-2010, 03:37 PM
Brandi1069's Avatar
Yes, I gave them my VIN, and some info off the original computer, and they flashed a new one for me based on that info.
Old 06-23-2010, 03:41 PM
HARDTRAILZ's Avatar
Is the fuel pump running...I replaced one on my 87 s15 and it was supposed to brand new, and it never worked. had to take it back for a new one.
Old 06-23-2010, 03:43 PM
Brandi1069's Avatar
I replaced the fuel pump yesterday. I can hear it running when I turn over the key. Fuel pressure is normal in the mid 50s to 60.
Quick Reply: Serious Blazer problems...
