Serious sludge im my radiator
Ive got a 2001 S10 Blazer Xtreme with the 4.3 motor and its over heating big time. I popped the cap off the radiator and it looks like oil spewing out. Please help this is my daily driver. Jarrettray193@gmail.com
Are you still running Dexcool? Air in the system will cause sludge build up. Two courses of action to take.
1. Flush your ENTIRE system and replace with the green stuff.
2. Flush your ENTIRE system and eliminate any air getting into the system (radiator cap is the most common culprit).
I drained the dex cool a while ago and ive been running the green stuff. The oil level is good and not milky and the trans fluid is good too. Im picking up a new radiator this week. I want to completely flush the block out of all the sludge but dont know how. I was told that the oil cooler is inside the radiator and it probably blew up and thats where the sludge came from. Also, because it over heated I'd like to check and make sure I didn't crack a head. How do i do that?
i had this exact same problem.What my grampa told me to do is put dawn dish soap in the radiator run a little while and drain it.the first time doing it you will see a huge improvement,but do it 2 or 3 times.worked amazing.I tell ya those irrational old guys have some good ideas.not evan the radiator flush stuff i bought a napa worked.let me know if it works for you.
zombiewoof
Feb 17, 2008 07:03 AM
