Serpentine Belt Tensioner Type?
My 96 Blazer has the original OE belt tensioner. As far as I can tell, it's a flat type spring with a fiber washer between the two casings.
I believe the Gates tensioner has a coil type spring. My pulley on the unit is fine.
I am wondering if I should replace it or let it be? I don't have any belt squeals.
Thanks
Thanks
I replace them every 60,000 miles or 4 years, along with the belt and the idler pulley as a preventive maintenance measure. Never had a problem, don't want one. Dayco tensioners use the flat style spring, which is a better set up than the coil spring. Make sure you use a name brand belt: Dayco, Gates, Goodyear etc, stay away from the el cheapo's.
RE: Belt Tensioner Type
Thanks for the feedback.
lionel2
09-07-2012 02:45 PM
luvmychevy
06-08-2011 11:46 AM
abig84
12-31-2009 05:40 PM
05, 1996, 95, 96, belt, blazer, chev, chevy, rattling, replacement, serpentine, serpertine, setup, tblazer, tensioner
