Service AWD light questions
Old Dec 19, 2015 | 04:45 AM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Default Service AWD light questions
About a month or so ago, I replaced my transfer case. For a while, it was fine. AWD was working great, no crow hop, no binding, all that good stuff.
Just recently, the service AWD light came on. When I turn the key on, I hear a clicking coming from the passenger's kick panel and the AWD light stays on. The clicking stops after a couple of seconds. I just went and tried it out on a nearby dirt road, and I think the AWD is working in and out. When I put it to the floor, I feel the rear wheels slipping and acting like traction control is coming on like in my Alero. It jumps. It's like slip, grab, slip, grab. What could be the culprit? I'm hoping just corrosion on the tccm.
99 Olds Bravada NP136
Old Dec 20, 2015 | 08:54 AM
ntjoe's Avatar
ntjoe is an unknown quantity at this point
The best, easiest way without throwing parts at it would be to get someone that has the proper tool to read the AWD codes. I know I ran threw my own NP136 woes and it turned out to be the encoder motor, but it could be a number of things.
The code reader will tell you what it is most likely. There is no cost in checking for TCCM corrosion and ensuring you have no wires loose it broken, but beyond that you'll be throwing money at it.
Something else that was recommended to me was to ensure the fluid was fresh with autotrack II fluid, which you can get at the dealer or on Amazon as I have found.
Old Dec 20, 2015 | 09:22 AM
When the t case was changed, I put fresh autotrak 2 fluid in it from the dealer.
Old Dec 20, 2015 | 09:17 PM
ntjoe's Avatar
I'd recommend finding someone with a scanner capable of reading the NP136 codes. I suspect it's either the transfer case clutches (as you said slip, grab, slip, grab), or the encoder motor itself, but this is just my opinion. You can't go wrong checking for corrosion in the TCCM connectors or plugs around the encoder motor.
Old Dec 21, 2015 | 03:30 AM
The tccm only clicks when the key is turned on, before starting. Would the tccm still click like that if it was a mechanical problem?
Old Dec 21, 2015 | 02:03 PM
ntjoe's Avatar
No idea, I'll check what mine does when I leave work today and let you know.......
Old Dec 21, 2015 | 08:34 PM
ntjoe's Avatar
Mine clicks when I turn the key also, so sounds like a relay click for power to the encoder motor. Again makes sense to get the codes read but I'd bet it's your encoder motor.
Old Dec 22, 2015 | 12:14 AM
That's what I'm hoping. Mine clicks like 4 times, the service AWD light stays on. I'll pull it and clean it this week.
ntjoe
Nov 12, 2012 05:35 PM
pettyfog
Aug 30, 2011 10:19 AM
vossyezco
Mar 30, 2010 06:52 PM
98BravadaST
Jan 16, 2010 12:35 PM
rednekk
Apr 17, 2008 09:09 PM
