Service Engine Light Code?
Old Jan 4, 2007 | 08:29 PM
flyinbrad's Avatar
flyinbrad is an unknown quantity at this point
Default Service Engine Light Code?
So the service engine light came on today and I took it by AutoZone and had them run the code. It is P0410 which is "The PCH has determined that a malfunction exists in the secondary air injection system" Any idea what this is or where to start on troubleshooting?
Old Jan 4, 2007 | 08:46 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: Service Engine Light Code?
GEE it would sure be nice to have some CRITICAL VEHICLE INFORMATION, but you need to check for a blown 30 amp maxi fuse right beside the battery behind the right headlight in the right fender. This code is usually caused by a blown fuse which is caused by water intrusion into the secondary AIR injection pump. There is an updated kit to relocate the inlet hose for the pump to keep water from getting in it.
Old Jan 4, 2007 | 08:57 PM
flyinbrad's Avatar
Yea I guess some specs would help. Sorry. 2001 Blazer 4wd 4.3L Auto. Thanks for the tip. I will go check now.
Old Jan 4, 2007 | 09:15 PM
flyinbrad's Avatar
Not the fuse. Just checked and it is good.
Old Jan 6, 2007 | 01:34 AM
flyinbrad's Avatar
Any more ideas?
Old Jan 6, 2007 | 01:36 AM
It is possible that the air pump is locked up or just gone bad. It is located under the radiator. If you remove it, you may be able to bench test it to ensure that it is working.
Brian5792
Sep 13, 2017 07:03 PM
loppy crimp
Sep 11, 2008 08:31 PM
chevyrocksu
Nov 18, 2007 06:07 PM
TwilightEpitaph
Aug 11, 2005 01:06 AM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
