SES Code P0452
Here is a link to the trouble code which will walk you through the process of trouble shooting the code from start to finish and should identify the problem:
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
As well as a link that will show you the threads where others have posted about this same code --> Search for "P0452"
Thanks for those. I read them over and looked through the search results, and honestly, a lot of it went over my head. I am pretty mechanically inclined but I have limited access to tools and only know the location of major parts in an engine bay.
Is there a common problem that causes this code? Or since I don't have many tools, should I just break down and take it somewhere to fix?
Also, is this something that needs to be fixed ASAP? I'm starting a new job next Wednesday, and moving between now and then, so if I could use the truck until after then it would be awesome.
Thanks!
Thanks!
PogiMoto
Dec 15, 2012 12:03 AM
