shakin'
Old Feb 22, 2009 | 09:26 AM
SCOTTY's Avatar
SCOTTY is an unknown quantity at this point
Default shakin'
Hi All:
I have a 97 s-10 blazer and the thing started a wicked shaking/vibration in the front end, I checked the ball joints, tie rod ends etc... and they all seem ok. Would a cv joint cause this kind of vibration? I only get the vibration when the engine is under load, if i just coast there is no vibes
any help is appreciated
thanks
scott
Old Feb 22, 2009 | 02:29 PM
Default RE: shakin'
Assuming you have a 4WD as you mention CV joints... Does it do it in both 2WD and 4WD?
Have you checked the motor mounts?
*Moving to 2nd Gen Tech*
Old Feb 22, 2009 | 03:58 PM
SCOTTY's Avatar
Default RE: shakin'
haven't checked 4 wheel drive, motor mounts would do that???
Old Feb 22, 2009 | 04:24 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: shakin'
Is the steering wheel shaking also??? are you sure the front wheel lug nuts are tight? did you check the idler arm and centerlink?
Old Feb 22, 2009 | 06:04 PM
Default RE: shakin'
A fan hitting the shroud could be described as you have... Just a thought.
Old Feb 22, 2009 | 09:30 PM
SCOTTY's Avatar
Default RE: shakin'
does the same in 4wheel or 2 wheel drive, lugs are tight, nothing in the suspension seems loose at all, i will look at motor mounts tomorrow
SCOTTY
Feb 22, 2009 02:29 PM
