Shaky side mirror...
My passenger side mirror is shaking like crazy, it looks like it is going to fall off every time I drive it. How do you remove the mirror and install a new one?
Blazin 4x4 |
RE: Shaky side mirror...
depends what yr it is. if its pre 94 then there are about 3 screws on the outside, that you have to take off. If its after 94 then I think you have to take the door panel off and there is 3 nuts you have to take off.
1998 Chevy Blazer LT 4x4...Does anyone have detailed instructions on how to do this? Especially how to get the door panel off.
Thanks, Blazin 4x4 |
It is really easy. On the door handle(the one that you use to pull the door shut.), there is a little piece of plastic that you pull out. Then you use a phillips head screw driver to pull 2 screws out. Then starting in the lower back side and just pull on, it in the corners. and it comes off, be carfull not to beak the plastic and of the wires for the speaker and power windows/locks. Then in the upper right side of the door there are 3 caps you pull out and then behind them there are 3 10mm bolts that hold on the mirror.
Thanks for the info. Sounds easy enough.
