Shaky side mirror...
Old Oct 7, 2005 | 01:27 PM
Blazin 4x4's Avatar
Blazin 4x4 is an unknown quantity at this point
Default Shaky side mirror...
My passenger side mirror is shaking like crazy, it looks like it is going to fall off every time I drive it. How do you remove the mirror and install a new one?
Blazin 4x4
Old Oct 7, 2005 | 05:25 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: Shaky side mirror...
depends what yr it is. if its pre 94 then there are about 3 screws on the outside, that you have to take off. If its after 94 then I think you have to take the door panel off and there is 3 nuts you have to take off.
Old Oct 13, 2005 | 07:14 PM
Blazin 4x4's Avatar
1998 Chevy Blazer LT 4x4...Does anyone have detailed instructions on how to do this? Especially how to get the door panel off.
Thanks,
Blazin 4x4
Old Oct 13, 2005 | 09:24 PM
blazin97's Avatar
It is really easy. On the door handle(the one that you use to pull the door shut.), there is a little piece of plastic that you pull out. Then you use a phillips head screw driver to pull 2 screws out. Then starting in the lower back side and just pull on, it in the corners. and it comes off, be carfull not to beak the plastic and of the wires for the speaker and power windows/locks. Then in the upper right side of the door there are 3 caps you pull out and then behind them there are 3 10mm bolts that hold on the mirror.
Old Oct 14, 2005 | 01:03 PM
Blazin 4x4's Avatar
Thanks for the info. Sounds easy enough.
Wexinlo
Apr 6, 2011 11:35 PM
musclecar70sfan
Dec 12, 2010 03:40 PM
santmire
Oct 12, 2009 11:42 AM
Canadian88
17
Jun 24, 2008 06:38 AM
joey
Dec 17, 2006 09:47 PM
