Signal lights Relay Location 97 Blazer S10
I would like to ask if somebody knows how to locate the signal light relay.I have a 1997 Blazer S 10 automatic 4WD.The info that I have said under the Instrument Panel ,but I couldn't find it .Do you have to remove the panel or the Radio .
Any help will be appreciated.
Thanks
Tony
Thanks
Tony
don't know if this helps but i've got a '97 Blazer LS and found a panel in the glove box that had 3 relays. there's a cover straight in on the top. kind of a pain to get off.
the turn signal relays are behind the panel that houses your cig lighter. you will need a torx bit to get that panel off, as well as a 7mm socket to take off the knee bolster. The relays in the glove compartment are the fule pump relays.
Thanks for the info .I'll try that.
Tony
Tony
Dragon9
03-03-2021 10:27 PM
1997 red blazer
02-10-2010 01:10 PM
Dohcser
06-13-2009 10:34 AM
Poke626
07-02-2008 02:37 PM
