Slow lifter?
#21
I hate suggesting snake oil, But seafoam works for me. Lifters and complicated little buggers. They work great until they dont work great anymore. Usually a little pirece of carbon gets stuck in a little itty bitty hole. Try the seafoam, It wont hurt.
#22
Whats the longest amount of time you can run seafoam in the motor until it starts to hurt stuff?
#23
I only run it for about 20 minutes at idle. i dont drive it with seafoam in it.
#24
a little update... after reading a can of seafoam, it says it can be used for long term cleaning. So i put the amount it says in the oil, ill drive it for awhile and see how it ends up.
#25
if that doesnt work you can put transmission fluid in the oil and it should help. I had a jimmy that did the same thing. I drained the oil and filled it with straight trans fluid. Ran it for about 15min then drained it and mixed oil and trans fluid 25/75. Ran it for another 15min then drained it and added 50/50 mix. Then 75/25 and finally back to straight oil. Im sure some people will tell you that you shouldnt do that but trust me. Its not going to hurt anything. I just wouldnt recommend running it with a mix in it for a long period of time. The detergents in the trans fluid will break up any sludge and varnish that is most likely causing your lifter to stick.
The cause to the sludge build up is probably coolant leaking into the oil. I would recommend doing a pressure check on the cooling system. I found my intake was leaking which is common on these motors. So i had to replace the intake gaskets too. After all of that my ticking was gone.
#26
#27
Whoever had it before me just had the oil changed from a big dealership in ohio. after it runs for a few seconds it stops doing it, so i thought maybe if all the oil dont drain back then it would help...i dont know. My dad says just drive it, but man this will drive me crazy lol. I might try a can of seafoam and see what happens. thanks
#28
Ok guys i know this is old. Ive replaced the lifters,intake gaskets,spider injection,oil lines, new filter, oil, new fuel filter, and water pump. I know most of that has nothing to do with the lifters ( just a run down). Basically with all the new parts, it still has this random tapping. Its not as bad as before, but it still does it...any ideas?
#29
whats your oil pressure?
#30
