Smog pump issue
Old Aug 1, 2011 | 09:21 AM
robrote's Avatar
robrote is on a distinguished road
Sorry, I know this is a little repetitve, but my smog pump which is 6 months old is toast. It was full of water. I'm trying to get through emissions.
Why do these things take on water? Anything else I should look for?
99 v-6 Auto, 4X4
FYI, its posting all the normal fault codes for the emissions system.
Last edited by rriddle3; Aug 1, 2011 at 09:40 AM. Reason: COMBINING CONSECUTIVE POSTS
Old Aug 1, 2011 | 10:55 AM
What does the intake tube look like? It should run up along the radiator fan shroud and then have a 90* bend in it with a 45* or so slash cut end. GM revised the intake tube sometime in '00 or '01 if I remember correctly.
Old Aug 1, 2011 | 11:17 AM
robrote's Avatar
It has the long hose that run up the shroud and into the wheel well. No 90 degree elbow.
Old Aug 1, 2011 | 11:56 AM
THIS SCHEMATIC (courtesy of Compnine.com) shows the revised AIR pump intake tube (#10). Like I said, it should extend up to somewhere above the middle of the radiator near the battery It shouldn't just be laying down on the fender. The schematic also shows the plastic clip (#11) that holds it to the shroud.
Old Aug 1, 2011 | 12:58 PM
robrote's Avatar
Ok thanks. Mine runs inside the fender well, but does not have that elbow. I will have to pick that up. I have also replaced the check valves proactively along with this pump.
Old Aug 1, 2011 | 01:06 PM
No problem! I did some quick searching and it looks like this hose may not be available except with the pump assembly. The TSB (#04-06-04-015A) mentions 17803252 which is the entire pump assembly and should include the new intake hose.
Old Aug 1, 2011 | 01:09 PM
robrote's Avatar
Oh, my aftermarket pump did not come with the hose. I'm sure I can make something up to mimic the one in the diagram
Old Aug 1, 2011 | 03:15 PM
robrote's Avatar
New pump is on, check valves replaced, new gas cap. SES light still on Shoot me now.
truesmack
Feb 8, 2009 10:21 PM
99blazer4.3
Nov 15, 2008 07:34 PM
slk34
Jun 28, 2007 10:07 AM
jajfromga
Jun 17, 2007 05:15 PM
desrt_rat
Dec 22, 2006 04:10 AM
