Smoke coming out of vents
Old Sep 1, 2009 | 07:36 PM
RomanCatholic's Avatar
RomanCatholic is on a distinguished road
Looks like it is the heater core. Radiator was bone dry, filled with water and turned on the heat....water in the cab on the drivers side floor board. I am gonna tie the intake and output hoses together that run to the heater core. No problems with that, correct?
Old Sep 1, 2009 | 07:59 PM
You should not have problems connecting these two hoses together other than the possible difficulty due to the hose sizes being different.
I hope the heater core is your only problem. That is a lot of coolant to go through.
Old Sep 1, 2009 | 08:08 PM
There was A LOT of smoke coming through the vents. Where else could the leak be?
Old Sep 1, 2009 | 08:39 PM
AJBert's Avatar
Check your oil and see if you have coolant in it. If so then you've got a double whammy.
Old Sep 1, 2009 | 09:07 PM
What does it mean if their is coolant in the oil?
Will the oil look like the coolant?
Checked the dipstick, didn't look like any coolant in the there.
Old Sep 1, 2009 | 09:13 PM
rriddle3's Avatar
Please use the 'edit' button to add to or change a post if nobody has responded. Thanks.
Old Sep 1, 2009 | 10:47 PM
KD5NRH's Avatar
KD5NRH is on a distinguished road
Head gasket, generally.
Think brown mayonnaise; the water gets whipped in with the oil by the action of the engine. At any rate, it will look distinctly like there's something in there besides just dirty oil.
dontgetmestarted
14
Oct 19, 2020 06:21 PM
coeltonbozz
Dec 28, 2013 12:25 AM
shadow03
Nov 2, 2013 10:18 PM
NavyAirframer
Feb 7, 2011 11:01 PM
Bhinton
Sep 18, 2008 07:50 PM
